Very Hot Cabin
Hi,
Wonder if you can help, the heater temperature control in my 1989 coupe doesn't seem to be working. It is the air conditioning version which I was told by the previous owner to keep on, which I do. The temperature control knob when turned right down to low has no effect and the cabin still gets extremmely hot, driving at this time of the year with your windows down doesn't look that good!! Any ideas?
think you need to take it in to your local specialist rather than OPC, ie someone used to working on old 911s as it is probably a common failing they are familiar with....there was something like that wrong with mine when I got it , stuck heater flap or something , yours might be something electronic tho' if you have temp control and aircon
Hi Julie, use the search button ,there is a load of info here about wayward 911 heating systems.
