I have been asked to edit this posting to ensure forum rules about promoting products and servicesw are not broken. So if anyone is interested in the problems that can occur rarely to a Cayman S (but for interest sakes more likely to a 996 3.6 or 997 3.6 or 3.8) then we have just managed to complete section 5 of our buyers guide available on the Internet by going to our web site www.hartech.org and buyers guide section 5 or by this link
http://www.hartech.org/docs/buyers%20guide%20web%20format%20Dec%202010%20part%205.pdf . (please note the section 5 starts after the foreward). This is purely an information tool and by going directly to the link - you can avoid seeing anything else about Hartech - as there are no prices or direct sales information in the section. The forward does contain some generalisations but if all you want to read is technical information please skip that and go directly to section 5 a few pages further on.
If the moderator wants to alter this message to satisfy the rules pllease feel free to do so or remove it if neccessary.
The section 5 explains in detail the differences between the 3.4 Cayman S, 3.6 and 3.8 engines (the models that exhibit cylinder scoring problems) and earlier engines, the potential causes and various new solutions and road test results INCLUDING A RELATIVELY INEXPENSIVE SOLUTION.
For those wanting faster answers "" whilst increased piston to cylinder wall loading results from increased bottom end torque "" at the same time changes to the coolant flow and distribution increase the temperature of localised hot spots and in some combinations of driver style, other older typical wear/age related problems, and general deterioration - push them beyond safe levels in an engine type already running hotter (but previously better balanced) temperatures than older typical designs. The result in some combinations of circumstances is too thin an oil film being unable to keep the piston and cylinder wall apart safely and resulting scoring of the piston and cylinder.
Fitting a lower temperature thermostat (while checking out other contributory factors) will lower the odds of you experiencing this failure while new exclusive pistons and modifications to the inside of the engine during a rebuild - will reduce repair costs further and protect against a reoccurrence.
All this research, design, rebuilding, testing and sharing our results with everyone takes up enormous amounts of time and energy "" hence often too little left to promote our excellent standard products and services in a more market orientated "" reader friendly style "" sorry - but I hope the information will help those unsure what to do to protect their interests, enable them to fully enjoy this fantastic model range and if they are unfortunate enough to experience the consequences (which is extremely unlikely) "" remember you can potentially incur unnecessary expense by not checking what your chosen investigative would or could do and what it would cost before authorising it.
The Cayman S is the least likely to suffer this problem but we have repaired some already and it may be worth checking up on, protecting against.
My very best wishes and good luck for the New Year "" until then
Baz
Baz
