vibration from exhaust
- Thread starter Guest
If they are fine then check the exhaust heat shields they also tend to rattle at low revs as the bolts/nuts holding them on tend to rust as well.
Michael Downing
It turned out that my tips had a support strut leading back to a clamp on one of the exhaust pipes. The strut had become detached from the tip and was rattling against it. So the OPC just undid the clamp and took the strut off. Problem solved ... no adverse effect!
