vibration !!!
- Thread starter guychris
morris944s2john
I have come to regard proper balancing of wheels as something of a black art of late. I got the front wheels on my S2 rebalanced for the fourth time a couple of months ago - by the same place that did them on times 1, 2 and 3. This time they actually got it right (had they not managed it, it would have been back for a 5th time ... and the only reason I went there was because they were highly recommended by several people ... )
I had my previous porsche balanced countless times to make no difference at all really in terms of being acceptable. eventually I remembered my days fitting on trucks which had their wheels balanced whilst fitted to the hub or simply on the vehicle.
Hardly any will have such a machine these days but there are still some around.
Balancing on the hub takes away any influencial causes of vibration from the hub and strut etc. the result was much much better. if all else fails then this is a good option as your vibrations may be caused by other stuff. You just need to remember to put the wheel on the same way you take it off to avoid those wobbles coming back.
I hope this helps as at the time I was having these troubles I felt just like the previous comment and it was spoiling the pleasure of ownership.
cheers
Paul
Therefore, I'd interesting to hear something positive about it as an idea. Thanks Paul.
