Hi all, I have a 2.7 2001 Boxster, I noticed over the last few months a vibration around 3000 - 3300rpm in the cruise, also when on the over run a marked vibration in the same region, looked at lots of post all given mount, muffler, all sorts, went with the mount, very cheap and what a difference, no vibration, no thumps on bumps, better gear change, don't delay if you suspect... do it
Vibrations and engine mounts
- Thread starter chopper
GOOFY
One of the common wear items is the mount and I changed mine at 27k miles ! But what a difference - no drive line shunts on overrunn.Another item worth changing are the anti roll bars linkages= these wear out but they make the suspension and road feel much tighter once renewed - even on a car with 25k. !
