Diver944
I have one too Jim. Very easy to fit - took me less than 2 hours in total and that included replacing the chips in the ECU's. Gave me a very solid idle, immediately reduced turbo lag and also had to turn down boost a little due to the extra 'breathing' it allowed. The beauty is it adjusts fuelling to match whatever boost you are running and when I logged it with my Wideb and the fuelling was virtually spot on. You can't do that with just a chip Due to my setup eventually needed the Piggyback to get the best out of it and that did need professional help as it needed a lot of wiring spliced into the connector at the ECU. One more thing - be careful how you route the wires to the MAF. I was careless with mine and the first time I used the car at night, the popup mechanism ripped all the wires out of the MAF and left me stranded [
