sawood12
It seems i've been a bit nieve. I've noticed that my voltmeter guage has always read just above 12v and with all the electrics on it dips below 12v so i've assumed that the alternator must be on it's way out. I have therefore got hold of a 2nd hand alternator and was going to fit imminently. However i've just put a voltmeter accross the battery terminals while the engine is running and got 13.7v which is what I believe it should be reading. So it appears there is nothing wrong with my alternator and my voltmeter is just inaccurate (if only i'd done this check before buying the replacement alternator!). Anyone else out there had the same experiance and can confirm that this is the case - i.e. the voltmeter is not that accurate?
Cheers.
Cheers.
