scam75
Well-known member
Hello all
I've had this issue the whole time I've owned the car. Had umpteen alternators and batteries and it never changes. It's not the end of the world but I'm thinking something is not quite right. I get about 13.8 volts across the battery on start up. Gauge in dash agrees so pretty sure it works ok. The voltage will drop when I switch things on, to the extent of being barely above 12 when lights, full ac and demister is on. The gauge pings back up when these things switched off, but not always back to 13.8v. It's not uncommon for it to only climb back to 13v for example after switching things off, sometimes it does go back up to 13.8v. Also see a small dip when brake pedal applied.
So I've changed alternators, second hand, refurb, new, no difference. Different batteries make no odds. Earth strap at battery is sound. Main earth in engine bay is sound. Connections to alternator are sound. I can't help thinking it must be earth related but if so, where else should I check? Also it is advisable to grease the battery terminals or spray some de-oxit or the likes on the battery connectors? As I say it's no massive deal but I don't think I should be seeing only 12v at idle with all my things switched on?? I understand some fluctuation is normal but I think I have too much?
Any thoughts welcome.
Stuart
Stuart
