VRam distribution piece
Alan Stamper
Whilst looking at the tech articles..on replacing dist/rotors note the comment on replacing the VRam distribution piece...can you plse advise where this is and if poss a part number so that I can get this from the OPC...who didn't seem to know what a VRam distribution piece was !
Thanks, Alan
Do a search on Rennlist there have been several posts recently showing pictures part numbers etc. Failing that Maurice is bound to know!
pp
Have a look inside the nearside rear of the engine compartment.....you may need to remove the heater blower if you have one fitted....this is the rubber union that joins with the flexy hose coming from the inner wing.....problems arise when the rubbery part flattens and becomes less round restricting the vacuum.....
I recently checked over my v/ram system, but this part was fine......if you need to replace try part no; 993 110 573 00. It will take minutes to fit in place.
