Wanted 924S wheels
Lizard
I'm after a set of 5 stud S wheels if anyoes got any, daftly sold a set for peanuts years ago & need them now Doh!
Woudn consider turbo wheels if cheap enough, think they are the same offsets? but prefer the teledials
Oh & not 944 offsets as wont fit!
I've got a set of 944 cookie cutters if anyone wanted a trade, or if not then good old fashioned cash ;-)
I have a set of 15inch teledial taken from my 924S, I Painted over them but it will soon come off, they have brand new tires (GoodYear Eagle) no kurb damage, I would be interested in a swap.
Excellent that could work well then, I'm away for work all of next wk, we can sort stuff when I'm back then
Cheers.
What are '944 offsets'? The 924S uses the same offset as 1987 onwards 944s, but with a 6" rim as opposed to the 944s 7". The Le Mans limited edition actually used a 7" 944 rim at the rear (rear only as opposed to all-round, from memory, but they fit all corners if you like).
Im guessing that you are referring to the early 23mm offset, found on ATS 'Cookie Cutters' and 1986 model years 944 ATS 'Telephone Dials'?
Simon
I'm guessing he wants them to fit on a 924S, which my wheels where off so I know they will fit. Couldn't tell you what the off sets are ?
Excuse delay work got in the way, yes its 924S wheels Im after, the cookie cutters I fitted but stuck out a good inch [:D]
usermjg I'll drop you a pm.
cheers
Im with you - 944 telephone dials (1987 model year onwards) will fit too. Theyre one inch wider and the same offset (52.3mm).
Simon
im doing a 5 stud conversion to my 924,
Is the standard offset for a 924S 52.3mm ?
I plan to fit the hybrid setup 6j front with 7j rear Design 90s
Sick man
OK, so two contradictory versions of the offsets for 924S?!
Is it 23mm or 52mm? I have been looking for some 7" 944 rims and thought that I needed the early 23mm offsets?
ORIGINAL: A9XXC
No - 23mm offset on 924 s and early 944
Youre incorrect Mike: the 924S certainly doesnt share the early 944s offset. You can see this by looking at the wheels and it is confirmed on the 6" telephone dials (ET52.3).
Simon
