Wanted Urgently LSD Transaxle
- Thread starter Guest
I can't make up my mind wether to go for a rebuild before putting the new one in or install the new one and keep the old for rebuilding.
I wonder if you'll still feel that way when it's right in the way of connecting the drive shaft []ORIGINAL: John Sims
My previous transaxle didn't have a cooling coil so, by default, I've ended up with an upgrade. []
Note by John - I've just noticed the time on this posting. Can I assume that Fen was catching up on the forum before leaving for Crawley? That it keen to the point of obsession. [&:]
ORIGINAL: tommo951
John I am really pleased for you mate!
Just wish I could lay my hands on one at the moment
Phone Douglas Valley Breakers on 01257 472866 , they had two.
ORIGINAL: Fen
I feel that I will most likely subcontract. Now should I have the clutch done while I'm about it?
Hilux
Oh yesss [][]
Been there, done that. Problem is that you cant unbolt the cooler `pipe`. If I had a gear box on the bench I`d certainly adapt it so that the cooler pipe could be unbolted otherwise you have to remove the trailing arm to drop the halfshaft, what an unbelievable pain in the rect*m
I have had a cooler on all my transaxles and never had a problem with removing the coolers to get the half shafts out.
They are flange fitting at the back of the gearbox and as I remember there is an allen key and 10mm nut securing to a bracket and if I remember rightly the front of the cooler is just a straight push in flange with a retaining bracket.
I found that second time round I could get the box out in 40 mins with the right tools. first time was 2 hours without the right tools. The biggest pain in the ass is the rubber mounting on the crossmember, damn fiddly.
Just out of interest has anybody fitted a 6 spd out of a 968, I know it is a different torque tube and drive shafts, just fed up of eating boxes!!!!
ORIGINAL: Fen
.........John - you'd be a mentalist not to replace the clutch IMO. OK it's a bit of extra work (but you have the 250 downpipe now at least?) but extra labour is insignificant compared to doing it as a job in itself. Clutch costs a bit but not a fortune. Remember the law of "while I'm in there..." []
That was pretty much the conclusion I had come to, particularly as I'm starting to loose track of the number of recent clutch smoking exploits - isn't it funny wen you pull away from at an uphill junction and the car starts to bog down that you don't consider you may not have sellected 1st gear [&o]
Hilux
I must get back under the car then. I understand exactly what you are saying re retaining flanges cos thats what I expected to see but mine go straight in with no retaining plate unless the retaining plate is huge
Retaining plate being `oval` plate with bolt/s that holds pipe flange/seal into box?
ORIGINAL: Hilux
Oh yesss [][]
I removed the driveshaft (by splitting the CV joints) with the cooler in place without too much difficulty. I think I had the car sitting on its wheels though rather than jacked up on stands, or maybe I jacked it up to get it out.
Tony
