Warm air when control set to cold
smitty893
Can anyone help - I keep getting warm air even when the temperature control is set to cold, but not all the time. Seems to have a mind of its own. It's even warm just after starting up.
Hi Smitty893
Sounds like it could be the infamous plastic clip on the heater servo.
http://www.porscheclubgbforum.com/tm.asp?m=271157&mpage=1&key=heater&#271157 should provide the starting point for your quest for cold air.
You'll need to whip out your glove box (remove the fuse for the glovebox light first) and check if any of the clips connecting the servos to the heater flaps are broken.
Phil
You mean the old mini? thats cable operated and will only work on square dash cars.
If its an oval dash car usually the heater clip, sometimes missing vacuum to the valve or a faulty servo motor (beside the glovebox with the plastic clip)
90% of the time its the plastic clip on oval dash cars.
Tony
yes as you say its 9/10 the cable clip but if it isn't it might be the heater valve as I suggested. Thats what was wrong with mine.
There was a very good article on this valve on rennlist some time back. The poster suggested using a mini vheater valve because it was made with metal as apposed to plastic and lasted longer and was more reliable and was cheaper.
I cannot remember which model mini unfortunatly .
Incidentally mine was an 86 Lux but with an oval dash and the cable operated heater valve so maybe they changed to electronic control soon after ?
