wolfie308
Do you check all the warning lights on the dash each time you start up?........me neither!
Do you run your fuel down till the warning light comes on, then think about filling up soon?.....I often do.
A couple of days ago, the car would turn over fine but wouldn't start. Although the light hadn't come on, the needle was
at the bottom of the red, so I knew it was err..pretty low. Decided to get a gallon from the local garage just in case, needle cleared
the red zone, and after a bit of coaxing, engine started and ran fine. I switched off and when I started again, I happened
to notice the low level lamp wasn't lit.
Doh!....I then realised I had actually run out of juice.....luckily it was outside my house. Moral of this story - do check to
see that your lamps are all working.
