WARNING LIGHT
My battery light has started staying on while the car is running, does this mean there is a problem with the alternator, if it a job you could do yourself or is it a garage job. Cheers guys.
Most likely the alternator or the voltage regulator, put a meter across the battery and see what volts you are getting, should be no more than 14volts. If you are handy with tools it's a DIY job , but fiddly, otherwise put it into a reputable Independent.
