Washer Fluid
- Thread starter skendrick
Dave Wilkinson
Porsche do sell an "Intensive Screen Wash" product which is intended to be put in the small reservoir you mention. The pump is operated by a separate rocker switch on the dash and supplies a metered amount of the screen wash to the screen - the screen should then be wash/wiped by the normal column lever switch as usual.
I don't recall meeting anyone who confessed to buying the Porsche product or even using the intensive wash reservoir. Be careful about using neat washer additive in there since many can be detrimental to the paint finish - something the Porsche product professes to avoid.
Dave
wouldnt suggest this for the porsche though !!!!
when i had my car zymolled , i asked glynn the detailer about what to use to avoid damaging the wax .
cant remember what i now use on the 964 , but will check when i get home .
have heard it mentioned loads of times about neat fluid damaging paint , but noone thinks that it'll take off the wax first , so you should be asking the wax maker
