Washer jets dont work
- Thread starter Guest
Andy Duncan
If you have already tried to clear the jets with an air line, then to prove its the valve(s), disconnect the feed pipe at the nozzel (you may need to break the little metal hose clamp) then operate the washers, if water comes out of the hose then its the valves, if not it could be the electric pump in the reservoir.
If you take the valves off completely using common sense and blowing thru them you can determine if they are working or not.
I cut all the metal clamps off when trying to resolve this problem and replaced them with tie wraps and have no leaks.
In order to re use the valves, I simply drilled thru the inner plastic piston from the top and side outlets, being careful not to drill thru the outer casing of the nozzels!!
good luck
andy
