Hi,
Neither the windscreen washers nor the headlight ones have worked since I bought my car. Today I got 'round to investigating and found both pumps had packed up and the relay: 92861811100 pulls in when you push the stalk away but you can hear it click out again after just under a second while the stalk is still pushed forward. This leads me to believe I need a new relay and obviously two new pumps.
I've found a headlight washer pump and the 92861811100 relay so I just wondered if anyone'd be able to tell me the best place to buy a winscreen washer pump for my '87 944S. And whether there is a second relay which does either the headlight pump or the windscreen one (whichever the above one doesn't) and where this one is located in the car and where to buy a replacement.
Thanks for all your help
H
H
