jonnyporsche
What's the easiest way of getting a wastegate off when the nuts are f****d. Sensible answers only please []
Buy both sets of these and you will never look at rounded bolts with the same sense of fear again. These things are a must in any tool kit and are worth their weight in gold.
I'm going to have a go at your advice George. The wastegate bench tests ok, so a friend is going to re-stud it, a MBC is on order from Lindsey Racing (cut out the dreaded CV), I have a boost guage, renew the head gasket and belts etc. and check over the vacuum lines and the rest of the gubbins and see how she goes [8|]ORIGINAL: George Elliott
Been there John,
not easy but if you sort the studs it will go back in a dream - I have a tial and does not fit as good or do anything different.
good luck either way
George
944t
