jonnyporsche
I'm about to buy a TiAL F38 wastegate so my question is what spring should I order with it presuming I run standard chips, I have heard that it should be the same as max boost ie. .08bar 11.6psi am I right or wrong[8|]
What do you plan to control boost with? Standard cycling valve? Aftermarket controller? Else?
I would take the 0.4 bar spring.
When running an EBC you want to use a "soft" spring so that the solenoid will have to provide the "lowest" amount of work to regulate boost.
While modern ECUs triggering EBCs work on a PID algorithm (PWM output), the standard KLR works on a PI algorithm. There is no Derivative gain. Just for your information
ORIGINAL: jonnyporsche
