Had to remove the wastegate in order to replace the cross over link exhaust pipe & gaskets, (had it re-welded but the pipe moved during the process and did not fit !!).
Usual problems with seized bolts & snapped studs. During the process of drilling them out took the opportunity to check the valve sealing faces which were found to be
pitted so required a light clean up & re-lapping.
Question is. does the valve stem require any form of lubricant ? ( yes I appreciate that the valve guide is ceramic & obviously the high temperatures involved ).
Does anyone have any experience of this or is it best just left dry ?
Was thinking perhaps a light dusting of graphite powder ?
