Hi all, had my Boxster S 987 2006 since 2008 with no problems at all , now has 48000 trouble free miles but last few weeks the coolant level has been fluctuating to the point I now need to put about 2 cup full,s in some days but nothing other days with same mileage ? Strange, trusted garage put car on ramp but found no signs of leakage, think I read somewhere about the cap on rear reservoir in rear boot leaking and I have seen a vapour / damp around the filling area and on underside of rear boot lid, could it be this? Any thoughts appreciated...
Water/ coolant level ..
- Thread starter ianmac
Ian,
If there's no external leak of coolant I'd certainly start with replacing the cap before looking elsewhere, particularly since there appears to be evidence of a leak in that area. A cheap and simple fix - if it works.
Other than that I'd get the system pressure tested just to ensure that there defiitely isn't a leaking radiator, etc.
Jeff
ORIGINAL: kevinbm
I agree with Jeff - I noticed a lot of condensation around the rear bootlid above the coolant cap and around the cap oil filler area. New cap (04 variant) and the problem was cured - you can get original caps off eBay for around £20
Yep & I think they are slightly cheaper from OPC, in region of £16 when I last bought one.
Amazes me the price that some people get away with charging on eBay, wind deflector clips for 986 is a classic, they're about 4x as expensive on eBay than at the OPC!
