Hi Everyone
Got fed up having water inside the car as well as outside, so stripped everything out and spent many frustrating hours selectively masking & jet-spraying the car. I eventually found a small underground lake in the most obscure possible place, i.e. in quite a deep 'pocket' behind the brake master cylinder / brake booster assembly. Car is a C4 LHD, so that's on the right of the luggage compartment if you're standing at the front looking in, just forward of the bulkhead, which may explain why water goes into both the interior, and the boot. More time spent with rubber tube, bent wire coat-hanger plus kitchen roll, hairdryer etc. etc. So now I know where the water goes, but not where it comes from / how it gets in! Before I do more spraying (thereby filling the lake up again!), I wonder if anyone else has had this particular problem, or if there are any pointers, or advice on this?
Would be very grateful for any help, thanks in advance. Regards to all.
James
James
