I have noticed in the wet weather of late that that water seems to be getting in through the driver's door bottom sill and the carpet lining on the door rim at the bottom is soaking wet. If I run my finger along the bottom of the door then water drips of the inner carpet lining. However passenger side is OK.
Has anyone else come across this? I suspect it may be the rubber seals or something. Also any help you can give to sort this out? - may have to go to OPC or my local independent to get it checked out.
Any advice would be much appreciated as would like to get it sorted asap.
Many thanks.
Gary
Many thanks.
Gary
