Water Leak
reevers
My 1995 997 C2S Tip with 53k miles has developed a leak. The leak seems to be coming from the area near to the Alternator. Heard a screeching noise whilst driving, stopped and noticed the drips on the ground. Any ideas on what this could be?
It maye be 1 of 2 things:- 1. Coolant tank leaking (common)and needs to be replaced or the cap needs replacing - check the level, and seperately the belt is coming loose. 2. The water pump has been dislodged and the pulley is thus screeching and may soon come off (this happened to my 996 a while back) If the pulley comes off you will lose power to the water pump, alternator, power steering, A/C so this should be looked at quickly. Go to a specialist and have it seen to
