Looking for some advice... My Boxster 987.1S is coming up to 12years old and 60k miles, from what i can tell, there has been no coolant change or water pump in its service history. Despite coolant change not being a service item, it seems best practice to replace pump and coolant every 4 years - i guess I’m way over due although no water loss in the 9 months of ownership? Or should I fix on fail?
Does the original pump have metal, plastic or composite impeller? Looking at ECP pumps both come with metal impellors which the forums slate, any recommendations on impellor type and brand would be helpful. Also whether to change thermostat at same time and whether to go for a low temp one? Or is that more for hotter climates than the UK?
Do you need to remove undertray(s) to reach the pump? I had a brief peek under but seemed tray was in the way.
