cytefx
ok, here is the story, I am wondering if anyone can help
buy new waterpump, belts and all the other little bits.
start to dismantle the car, I have the clarkes manual etc, set the car to TDC as they say and put in my flywheel lock, take of all the other bits and pieces but leave the main crank pully till last
no I have managed to sheer a 1/2 inch drive extension in two trying to get the nut/bolt undone, rechecked TDC and it looked like it had moved (i can not locate it again, another issue.)
I am guessing my only option now is to get it to a specialist, like northway, although I can not drive it there, does any one know a specialist that will pick up a vehicle?
so nearly there on the disassemble, can not get the water pump off, as the back of the belt cover will not come off until the crank pully is removed.
oops
oops
