944cabby
I've had suspicions for some time that i've been losing water from the cab but assumed it was passing though the breather hose.
Anyways started the cab tonight with the bonnet up and noticed steam from around the plastic housing bolted onto the water pump - checking closer the water was sufficient to see on my fingertips.
Before i undo the bolts could anyone tell me if there's a seal or gasket i need to order (or the black housing itself?).
The pump itself isn't noisy so i'm hoping that's ok.
Cheers.
Cheers.
