GOOFY
Hi
What is the consensus on replacing water pumps as a precautionary move ?
I am in the process of replacing the steering pump/ water pump drive belt , and with the car now over 10 years old and just under 40k on the clock , and having read on forums about water pump failure and the damage it can cause due to immediate overheating, wondered if it would be a good move to replace the above.
I know that on VW's, the recommendation has always been to replace at 50k miles or 4 years, in line with the cam belt change. Indeed my Golf suffered a water pump failure almost exactly at this mileage. Presumably these pumps are the same design as the Boxster.
Should we be doing this as a matter of course on Boxsters ?
Is there any other method to check the pump is ok and not on its way out ?
Thoughts much appreciated.
Thanks for reading.
Thanks for reading.
