Here is a section from one of my old Boxster Register sumissions from Porsche Post back in early 2004:
Soft Top When new the Boxster top beads water very well, however after a while it can start to look like this is no longer working, the top is "wet" and it does not look so good. Never fear "" the top is comprised of several layers, including a neoprene one that ensures that you stay dry even in the worst rain conditions. However if you like the top to "bead" water in the same way it did when it was new then you can re-proof it. Several re-proofing products are available, you can look in Porsche Post or post a message on the Club Forum asking for recommendations. Once you have your product, you can start the proofing process. First wash the roof with a mild detergent (the ONLY time you should do this- use plain water at all other times, otherwise the proofing will be removed! Rinse well, then again, and again "" you want to remove ALL the detergent. Leave to dry thoroughly. Now on to the proofing itself: It is prudent to be careful not to get any of the proofing material on the paintwork of the car. I recommend buying a large, THIN, decorating polyethylene sheet (any DIY store). Cut a slit in it, then open the roof part way, and slide the sheet over the roof. You should be able to work the slit in the sheet over the front of the roof, along the roof, and under the back. Then you can close the roof again, trapping the sheet so that the windscreen, rear "boomerang" cover panel, boot, doors and windows and the bonnet are all covered. Then you only need to mask the rear window, and plastic roof trim. If you wish you might want to continue masking the lower areas of the car as well "" I just used a few sheets of newspaper stuck to the plastic sheet for this. You can then treat the roof with your preferred product. If the treatment you have selected is a brush-on variety then you may not need to be so comprehensive with the masking "" I guess this depends how messy you are! Allow the proofing to dry as per the instructions, remove your masking/shielding and you should have a roof that beads water once again.
