sawood12
Last time my car was in at the specialist he commented that the extension on my slave cylinder indicated that my clutch was pretty worn and probably not far of replacement. Since then i've been paying into my 'Clutch and Cylinder Head Gasket Replacement Fund' as I knew the bill when it comes will be a substantial one. However now i've got the cash sat in my little fund there is still no sign of my clutch slipping and the temptation to raid the fund for my long awaited and often delayed MAF kit purchase is very very nearly too much to resist any longer. However sods law says that if I were to raid the fund for my MAF kit the very next week my clutch will start slipping!! How much warning do the clutches on these cars give you before they totally give up?? I believe that the turbo clutches don't have the rubber damper mechanism that often fails on S2's so I imagine that the main need for clutch replacements on turbos is clutchplate wear which should give you plenty of warning before they completely give up the ghost.
I realise that this is something that is very difficult or even impossible to predict but is there a measurement I can take on the slave cylinder that indicates how much clutch friction material I have so I can estimate how many more miles I might have before replacement?? I'm not a heavy slipper of the clutch, I never (well almost never) do full clutch smoking take-offs, i'm am pretty slick at matching engine revs to road speed when changing down the box to minimise or even eliminate clutch slippage and I absolutely never ride the clutch on hills so I fancy my chances in buying time to replenish my clutch fund if there is some material left on the clutchplates.
