Wedding Cars
- Thread starter Lancerlot
Clive / Judy
Hope you all had a great day and that the weather was kind.
All our best wishes.
Geoff & Caroline
I hope the day went well and that your head and your wallet recover soon[
![zjd8qun.jpg](https://i.imgur.com/zjd8qun.jpg)
lem
Quick question on the 911 front number plate. Did you take the plinth off and did it leave any holes? I like the idea of the stick on plate but worry holes will be left and the stick on plate will be a little creased because of the curve on the bumper?
A stick-on plate was supplied from new, so the plinth was never fitted. Should you decide to remove yours, there may well be very small screw holes left. However, these could easily be removed by a competent body-shop or alternatively, concealed using pan or socket head S/S screws. Where there's a will there's a way! [
The original plate was replaced with a better, laminated version when the PPF was applied and you are right, it's tricky to fit. This is due to the triple radius shape of the TTS front bumper. However, if you persevere with sufficient lubricant and heat, you will get there and end up with a great result. [
Regards,
Clive
AlinaNielsen
AlinaNielsen said:The red one is especially amazing!
Yep. It's just coming up to 2 years old now and still amazes me. ????
Dan, the bridegroom later confided secretly that driving it was the best part of his day!
Regards,
Clive
KaleBradford
KaleBradford said:Hey there! Thanks for bumping, now I want a red turbo s, guys! As for choosing a wedding car, it can be a tough decision, for sure. Do you know what they want exactly?
Strange first post given you joined the forum as a guest yesterday. Care to explain?
Kind Regards David
6DW said:The Turbo looks great Clive, I hope you all had a fabulous day. If you send a brief report and some images to 992@porscheclubgb.com we can perhaps use it in a forthcoming 992 Register report in PP. Kind Regards David
Thanks David,
I'm happy to do that, but it's not that topical really - I first posted this nearly 2 years ago, then someone just bumped it recently.
The issue from this happy union is my latest, 10 week old grandson, Archie James! [
![AbOuBax.jpg](https://i.imgur.com/AbOuBax.jpg)
