Pun intended but when it rains it really pours. First my driver's seat get stuck in 1 position then 2 days later the passenger side carpet is wet. Before anyone suggests the sunroof drains I know they are definitely not at fault. It is a result of what I did a few days previously.
Last Friday I took off the door trim to fix a rattle. I peeled the foam protector back carefully and noticed that the bottom edge just below the speaker was very slightly damp. After fixing the rattle, I stuck the foam protector back. The weather was dry until the weekend and the next day found the carpet was wet. I removed the door trim again and the bottom was soaked. I poured water at the glass and there were no leaks. When I poured water at the mirror, particularly at the edge near the door and the door window, there was a steady stream of water coming from a small gap in the glue strip of the foam protector just below the speaker. I am about to replace the foam protector with a new one but I don't think I am actually fixing the original problem of the amount of water leaking past the door seal at the mirror. I thought of replacing the seal until I saw the price of it (over £134 + vat). Would anyone have any advice or should I bite the bullet and change the door seal 996 537 531 06?
