wet floor
- Thread starter zack
A couple of things come to mind;
1) Is the bottom of the drivers door wet too? It could be the door membrane has become detatched.
2) Is the drain under the hood blocked (partially open the hood so you can get under the rear cover)? There is a hole at a low point forward of the cover.
Andrew
These need to be kept clear as water that gets trapped finds a way out - and this can be to the cockpit.
Under the passenger seat there are expensive electronics and if these get wet it can be VERY expensive!
NickChivers
Be quick though - various, expensive to replace, electronics live under the seats (though primarily passenger side).
