Kongsodoken
So I put some power to to the car today to set the headlights and the window wipers etc
The headlights Work perfectly in manual mode turn the knob and they go up and down with no resistance
So I disconnected the headlight bar from motor and operated the motor by the switch fully up, fully down motor works perfect..going to be easy jobI thought[]
With the motor in the down position I re-attached the headlight bar, operated the switch...great up come the lights []
When I try and retract the motor just twitches and does not retract, tried several times setting at the top, bottom and the wrongway around
Up it works
Manually it works
Down no go
Help any ideas[&o]
Up it works
Manually it works
Down no go
Help any ideas[&o]
