What are the best lowering springs
Looking to lower my 996 C2 by circa 20mm can anyone suggest best lowering spring kit based on experience ? The most important factor is that ride is already surprisingly firm therefore I am looking for kit that if possible does not make ride any harsher than current. Any tried and tested advice would be greatly appreciated.
Hi mate, had a set of roock fitted to boxster S and have to say they were superb.
I did try a cheap option first and the coils kept rattling against each other, so would recommend a good make.
You say 20mm which you will find difficult I think, 40mm seems the norm (GT3 look) or you could opt for 10mm (standard OEM sport) but in my opinion visually not worth the bother depends on what look you are after !
