bones
Following a winscreen crack I took the opportunity to fit a later type screen with an inbuilt aerial to my '78SC (don't say post in the SC forum), I then bought an aerial booster from a Porsche breakers which is missing a vital connector.
Looking at the attached pic . I assume
2. is for the usual aerial connection at the radio itself, Does
3. need to be connected and what is it anyway, is it simply a copy of 3. with a connector for a different type of aerial fitting? Is the drilled mounting at
4. also an earth?
1. has the connector missing, I assume it connects into the screen female connector now residing behind my clocks, if I can't get the breakers to find one on Monday what type of male plug is this, special or easily available?
4. also an earth?
