what bulb`s best ?
davepaul993
what head light bulb is best ?
i have hids, but main beam is orange ! so with darker evenings would like to find out what bulb is the best one to use,
is whiter better or not ?
over to you.
dave
you could have HIDs fitted to the main beam as well...
i would really like to sort my side lights, as they look pathetic against the HIDs!
tim
ORIGINAL: tim993
Tim, do you think this would work?
I was going to do this. However I did the dips first and I'm sure now (at least with the model I used - HIDS4U) that the way they light up (initial brief flash, then dim for a bit less than a second, then fade up to full brighness over maybe 2 seconds) would mean they were not practical for main beam.
Agree with you about the sides. But I tried some cheap LEDs off ebay and they were dreadful - right colour but not enough light. I put the tungstens back in.
Hi Mark.
I only suggest this because i know that GT-One did a main and dipped HIDs conversion for a customer just before they did the dipped beams on mine. You could call Peter or Craig and see what they have to say - these guys know what they are doing, so I can't imagine they would have done it if there was a problem. Apparently it turns night into day even more so!!
BTW, do you have any solution to the side lights, or just stick with the old tungsten bulbs?
Tim
ORIGINAL: tim993
Tim, No, I'm still using the old tungsten ones.
I'd be very interested to hear if anyone's found a source for any bright LEDs for replacing the side lights. I also tried some from AceParts - but they were no brighter than the ones off ebay.
