What is best way to spend 15k on a Boxster?????
- Thread starter philthain
This will give you some idea as to what your money will buy .I think most will say service history is paramount . The fun is in tracking them down .Good luck..... on my 3rd Boxster great cars
Kevin Welch
Is there a reason given as to why you should avoid the Tiptronic?
http://www.pistonheads.co...y-edition-2004/4969465
I'm a bit old school but would always go manual. Tiptronic I would guess are not as popular and you may even find one a bit cheaper. A bit more on the Anniversary model below. Its the official Press Release.
PCGB Reading press release for Boxster Anniversay.
Boxster S Anniversary Edition
Porsche celebrates the 50th anniversary of its legendary sports roadster by launching its Spyder special edition
Porsche is celebrating the 50th birthday of the 550 Spyder by launching a powerful Boxster S special edition - limited to 1,953 units - and bearing the name "Boxster S Anniversary Edition". It is to be premiered in Detroit, USA in January 2004, and it is expected to reach the UK in March 2004. The "Boxster S Anniversary Edition" will be priced at £41,700 including VAT in the UK.
The Porsche Boxster is a direct descendent of the legendary 550 Spyder dating from 1953: common to both are the mid-engined roadster concept, low weight, outstanding agility, timelessly elegant body lines and a high level of driving pleasure. Now as then, every part of the car is dedicated to the demands of the enthusiastic driver resulting in the Porsche Boxster already having become a modern classic.
Porsche engineers have worked to enhance the roadster driving experience still further and have given the special "Boxster S Anniversary Edition" a series of sought-after equipment details and technical features that have not been available for the Boxster so far. The output of the Boxster S's 3.2-litre flat-six engine goes up by 6 bhp to 266 bhp (196 kW) at 6,200 rpm. The special edition has a top speed of 266 km/h (standard Boxster S: 264 km/h) and sprints from zero to 100 km/h in a mere 5.7 seconds (Tiptronic S: 6.4 seconds). Its maximum torque of 310 Nm is available at 4,600 rpm.
The exhaust system, which has a specially styled, stainless-steel tailpipe, delivers the typical Porsche sound. Porsche technicians have reduced the 6-speed gearbox's shift travel by 15 percent, a noticeable benefit that contributes to even greater driving pleasure whenever the car is accelerated. Tiptronic S, permitting driver selection of the chosen gear using toggle switches on the steering wheel, is an optional extra.
The car's true roadster character is emphasised by lowering the body by 10 millimetres and by sports suspension settings. This sports suspension improves the car's roadholding still further and permits higher lateral acceleration values. Porsche Stability Management (PSM) is installed as a standard to ensure optimum safety in all driving situations.
The brakes are another important safety feature. The cross-drilled brake discs have a diameter of 318 millimetres at the front and 299 millimetres at the rear. Exclusively for this special edition, the four-piston monobloc aluminum brake calipers have an aluminum paint finish. They are readily visible behind the larger 18-inch Carrera wheels (the standard model has 17-inch wheels). The spokes are painted in Seal Grey and provide additional visual emphasis. A coloured Porsche crest adorns each wheel hub cover. Five-millimeter wide spacers on all four wheels give the special "Boxster S Anniversary Edition" an even more powerful appearance and firmer road stance. Another feature that sets this model apart from the standard Boxster S are the grills finished in body colour above the openings in the rear struts, which recall the closed rear view of the 550. The Boxster S lettering at the rear is polished chrome plate. The colour of the padded front of the roll-over bars matches the interior. An on-board computer, Litronic headlamps with dynamic beam angle adjustment and a cleaning system are also standard.
Most of the original 550 Spyders were painted in silver. The special edition has therefore been finished in gleaming GT Silver metallic, a colour so far reserved for the Carrera GT and the "40 Years of the 911" model.
The soft top is in Cocoa, a dark brown colour used by Porsche for the first time on this special edition. The same two colours dominate the car's interior, with matching carpet and floor mats with the Porsche inscription. Dark grey natural leather is available as an alternative; in this case the carpets and the hood are in black.
In both interior colours, the leather finish on the centre panels of the heated sport seats, the handbrake lever, the gear lever gaiter, the inside door handles and the padded sport steering wheel provide exclusive visual cues and tactile features that give the interior a special character. The seat back shells, the rear section of the centre console, the handbrake lever, the grooved bar on the dashboard, the switch panel and the back of the roll-over bars are all finished in GT Silver, achieving a striking contrast. The black instrument dials are framed by chrome rings. The ball-shaped gear-lever knob is made of aluminum trimmed with Cocoa leather. The (optional) Tiptronic S gear shift cover is highly polished as is the Boxster S lettering that stands out against the black door sills.
This Boxster S special edition bears a limited-edition plate on the centre console indicating each car's individual production number. Automatic air conditioning, the Porsche CDR-23 radio with audio package and wind-deflectors are all standard and complete the package.
Notes:
Porsche presented the 550 Spyder to the public for the first time at the Paris Motor Show in October 1953. This fabulous two-seater was the first sports car from Stuttgart-Zuffenhausen developed especially for motorsport. Weighing just 550 kilos or 1213 lb, the lightweight Spyder was destined to score numerous wins on racing circuits the world over and in road races so popular at the time. A particular highlight enthusiasts still remember to this very day is the 1954 Carrera Panamericana, Hans Herrmann finishing third overall behind two much bigger and more powerful sports cars, thus bringing home victory in his class in this fifth and last edition of the toughest road race in the world. This outstanding success was to be followed by a long list of further victories and successful entries in motorsport by both the works team and a number of private customer teams.
Incidentally, the type designation of the car was not derived from its weight as is sometimes assumed; it was, in fact, the 550th Porsche design project.
Report from 21/11/2003
21/11/2003
Enjoy your Cars and Club
John Dunn
RO Region 24hi
I have manual 3.2S. My 'other' car has a PDK / DSG gearbox. Pays your money and takes your choice as they say; the manual is a joy to drive, whereas my experience of PDK style gearboxes whilst they are super efficient they take the pleasure out of driving a little
As Kitchens says, service history is paramount. I'd lean to a private sale with one owner (PCGB ideally) for number of years and plenty of receipts. If you do, get an inspection before you buy
Let us know how you get on
jdpef356 said:Example of 986 Anniversary - well within budget and all cars came with all the goodies as standard.[8D]
I used to have one of the anniversary models it was Tiptronic and loved it ,and my 987 was also Tip in fact my previous few Porsches where all Tip and I like them. Never had any issues . With any Ltd edition your depreciation will be minimal in some cases zero where as on a standard car it will be all depreciation even at the £15K level
PistonHeads have written and published a comprehensive Porsche Cayman 987 buyer's guide that offers help and advice to ensure you are well informed when making your purchase.
The Porsche Cayman 987 buying guide covers such key points as: Powertrain, Rolling Chassis, Body and Interior for you to use as reference guides.
We also have extremely knowledgeable members who can give you great advice, so feel free to get involved or post any pertinent questions that you may have!
Then when you’re ready, make your way over to our classifieds to see Porsche Cayman 987s for sale.
Although this is based on the Cayman all will apply to the 987 Boxster ..a good read
