What model 944?
- Thread starter Guest
How about posting a few snaps on we should be able to give you the details in no time.
The age could be a good clue and we could tell you that from the vin number.
On the age front :-
Pre 85 it is a Lux
86 - 88 Could be Turbo, Lux or S. Turbo will say Turbo on the back (bit of a give away) and also on the air box. The S will say Ventliner (or someting similar) on the rubbing strip behind the front wheels and have a twin cam engine, otherwise it is a Lux.
89 - Turbo or S2
On the back it just says 944 and you're right it's not rusting....just a load of moss!!
i've got a few pics but don't know how to put them on here. What is an old dash? The rev counter is 'upside down'
Leon
Diver944
The next two numbers will be either 94 (for a N/A) or 95 (for a Turbocharged)
The next letter is the model year starting at D for 1983 up to N for 92
The final letter is an N then comes the serial number for that individual car
Look at the model year letter and work out what it is from Johns post above as to what was made in each year. I will tell you now what it definitley is not - a cabriolet [
Sounds like an old dash as the rev counter is part of the instrument housing on a later "oval" dash model.
If the rev counter has been turned this could indicate that the car has been raced or rallied or previously owned by a boy racer. Racers often like the rev counter needle to be a 12:00 at optimum revs.
Diver944 the VIN starts like you say and then follows 94 for an N/A but then has either a 0EW or OEW as the next 3 characters. Would this mean that i am looking at an 1984 LUX? It does have a lot of electrics like windows, sunroof and a switch down by the accelerator pedal to open the boot!
John, the rev counter is on the right of the dash and has an MPG needle and the rev counter starts at approx 1 o'clock with 0rpm going round clockwise to the redline at 6400rpm ish at approx 9 o'clock.
Leon
has an MPG needle
That clinches it - it is a Lux.
The old dash is a very minor rework on the 924 dash.
Regards Barrie
Diver944
Take a look at http://www.cantonia.com/watercooler.html and on the page for engine and chassis numbers it explains it better than my ramblings in the middle of the night.
The O in your number means its a USA/Canada model
The E is for 1984
The W should be an N indicating it was assembled at the Neckarsulm factory
Is it a left hand drive model?
He told me it was a 1983 Lux that originally had an 'A' number plate although it's a private plate now.
Now that's similar to what i had thought from all the info i got from here but still doesn't match up with the VIN number as it should be a 1984 one?
So since the VIN starts WPOZZZ94OE would that imply that it is both a Europe RoW and a USA/Canada model? [&:]
Can anyone tell me what size/rating tyres are correct for it as well please? it has all 4 original wheels with 195/65 R15 91H on the front which can't be right!
oh yeah it's a RHD model.
Leon
WPO ZZZ = Europe RoW
WPO AAO = USA/Canada
94 = first two digits of model No. - Standard 944
95 = first two digits of model No. - 951 (944 Turbo)
Z = Europe RoW
O = USA/Canada
D= model year (1983)
E=1984 up to 1990 L (later ZL) 1991 ZM, 1992 ZN
N = Neckarsulm (build plant)
4 = last digit of model No. (944)
1 = last digit of model No. (951)
and wondered why the WPOZZZ would say europe row and the 940 say usa/canada when common sense would suggest that it should read WPOZZZ94Z or WPOAAO94O.
Diver944
ORIGINAL: LeonB
I can't find any info on the web just now confirming what the original size is but I really think you should put two of the wheels on the back [
