What oil to use?
- Thread starter Guest
Saying that, I use Mobil1 without problems!
Saying that! I think there's a oil guide on the forum here somewhere too. I'm a bit new, but I'm sure someone can point you in the right direction.....
Diver944
Turbos need a fully synthetic oil to cope with the heat from the turbocharger. Oilman on the forum does a great price for Silkolene
Normally aspirated 944s are fine on a semi synthetic. I use Magnatec 10w40 in my S2 for the past 70k miles, changing it every 6k
ORIGINAL: martincammack
Who has? Tell me who they are.
Well, if you do a search on Rennlist, you'll probably hit at least 20. It just seems that when reverting from mineral oil to synthetic, the better flow capabilities tend to make the seals weep a bit more. I've no experience of this, I'm just relaying what I've been told.......
Web site:
http://www.opieoils.co.uk/lubricants.htm
I've posted the actual recommendations for oil sent to me by Porsche on the 928uk website:
http://www.928.org.uk/mambo/content/view/104/0/
Good luck.
Diver944
Martin is spot on that Magnatec is not a synthetic oil, it is mineral based, despite what Castrol print on the pack.
However the benefits of a synthetric are that it will stay in its range for longer and after much more abuse than a mineral can take.
Oilmans extensive education has taught me (I think [
They are both blanket statements that don't take into account the grade of the oil. For example a 0W30 mineral oil will be much thinner hot and cold than a 15w50 synthetic so it will improve fuel economy, increase power etc. However under heavy use it will lose its grading much quicker than the synthetic and at that point stop protecting the engine as efficiently.
If two oils are the same grade, then the synthetic will be better quality, cope with extreme heat better and retain its grade longer so yielding longer oil changes, but potentially cost a lot more to buy.
I use a synthetic 5W40 in my Turbo because of the heat, but a semi 10w40 in my normally aspirated S2
oilman
It's a question of cost vs quality and I suppose "how much you care"!
Synthetics (proper ones made in labs by chemists) are better by design and will give the highest levels of protection to both engine and gearbox.
Which is where we come to the point of all this. You're running Porsche's not Ford Fiestas, don't be daft and just take the view that any oil will do in your pride and joy as it won't. Sure any oil is better than no oil but using a quality product will have benefits.
This article by John Rowland, Silkolene's Chief Chemist explains it well:
Quote:
Costs of synthetics vary considerably. The most expensive are the "Ester" types originally only used in jet engines. These cost 6 to 10 times more than high quality mineral oils.
The cheapest synthetics are not really synthetic at all, from a chemists point of view. These are in fact specially refined light viscosity mineral oils known as "hydrocracked". These have some advantages over equivalent mineral oils, particularly in lower viscosity motor oils such as 5w-30 or other oils with a low "W" rating such as 5w-50 etc and they cost about 1.5 times more than good quality mineral fractions.
We use several different grades of this base oil, where appropriate. This is the "synthetic" which is always [/b]used in cheap oils that are labelled "synthetic". Yes it's a cruel world, you get what you pay for!
Now, you may ask, why are these special mineral oils called "synthetic"?
Well, it was all sorted in a legal battle that took place in the USA about ten years ago. Sound reasons (including evidence from a Nobel Prize winning chemist) were disregarded and the final ruling was that certain mineral bases that had undergone extra chemical treatments could be called "synthetic".
Needless to say, the marketing executives wet their knickers with pure delight! They realised that this meant, and still does, that the critical buzz-word "synthetic" could be printed on a can of cheap oil provided that the contents included a few percent of "hydrocracked" mineral oil, at a cost of quite literally a few pence.
So, the chemistry of "synthetics" is complex and so is the politics!
The economics are very simple. If you like the look of a smart well-marketed can with "synthetic" printed on it, fair enough, it will not cost you a lot; and now you know why this is the case.
But, if you drive a high performance car, and you intend to keep it for several years, and maybe do the odd "track day", then you need a genuine Ester/PAO (Poly Alpha Olefin) synthetic oil, such as PRO S or PRO R. This oil costs more money to buy, because it costs us a lot of money to make, very simply, you always get what you pay for![/b]
Unquote:
Hope this helps,
Simon
berg944
I am limited in what I can use in a bike with a wet clutch as a lot of oils have additives that make the clutch slip.
I was thinking of using it in mt Turbo but......
Is it a real synthetic ? (it does say fully synthetic on the can)
Mike
