What`s a leakdwn test ?
Tony,
Not quite. A compression test will measure the maximum pressure generated within the combustion chamber by the piston on it's compression stroke. The result will give you a good idea of the effectiveness of the sealing around the piston and the valves for that short period of time that the space is enclosed.
A leakdown test - often also referred to as a loss test - is performed slightly differently. The piston is positioned at it's top dead centre and the combustion chamber is pressurised to a chosen level and the pressure monitored to assess the amount of pressure loss over time. This gives a better impression of not only the quality of seal achieved by the piston rings and valves but can also enable individual areas to be assessed to determine where leakage is occurring and hence, to determine what best remedial action to take.
Most proficient garages will be able to perform a leakdown test - it takes less than a hour on a 964 - and is strongly recommended as part of a PPI for any car.
I'm not going to get drawn on what is good or what is bad as there are many opinions but suffice to say that less leakage is better than more (hopefully that's obvious) and figures in the region of 25% or more are not considered good but in a high performance engine expected to undergo a hard life considerably less than that would be expected.
Other opinions will surely follow!!!
Dave
