What to buy S2 or TURBO
- Thread starter pal944
Helen Goff
No.1 Poster
If toys are important to you all Turbos had air-con whereas not many S2s did ~ it's based on the outlawed R12 refrigerant though which means it can be expensive to get it going again if it doesn't work. Silver Rose and '89 on Turbos had bigger brakes and LSD (earlier ones were similar chassis as S2s but without ABS). Later Turbos ('90 on) had bridge spoilers ('91 on for S2s) and most (all?) had leather which was rare in all but the last S2s.
Standard Turbos aren't very nice to drive whereas S2s generally are.
Very "off/on" type of power delivery.
You will either learn to live with the 'lag' or end up doing everything to eliminate it.
As with most car choices, have a go in a few and see what you prefer to drive and if it suits your needs.
(IMO) I don't think you could go wrong with either Turbo or S2, both have their foibles as I am sure you are aware.
ORIGINAL: wizard
LOL.
Off, off, off, off (tum-te-tum), ooooooooOOOOOONNNNNNNNN!!!!!!!!
But, its already been said. An S2 is still a pretty quick car, nice sounding engine lots of character, and feels quicker lower donw due ot the difference gearing (more so than any additional low down torque)
Turbos really are too tempting to start throwing money at them.
If you have deep pockets get a turbo, if you have slightly less deep pockets then the S2 will be fab.
ORIGINAL: Fen
ORIGINAL: wizard
LOL.
Thats why we have that waggly stick thing between the seats
Tony
sawood12
Having said that, when the road opens up and I get the chance to keep the turbo blowing through the gears I know i've made the right choice for me. The sheer kick in the back is exhilarating and it stays there right upto the red line in every gear until you bottle out (or hit the speed limit). It's times like that I think to myself "I made the right choice".
In terms of maintenance costs I doubt a turbo is any more expensive to run unless things really go pear shaped or you do get hooked on the modifying thing, and in any case you can get a 2nd hand turbo from a breakers for a few hundred quid so it wouldn't bankrupt you in the unlikely event that you did have turbo trouble.
Whatever you go for i'm sure you'll have a blast!
ORIGINAL: 944Turbo
ORIGINAL: Fen
ORIGINAL: wizard
LOL.
Tony
Actually that's why the good Lord made MAF/MAP, decent wastegates and credit cards [
TTM
Well-known member
The turbo 250 has more low down torque than even the S2 when it's off boost, at least from 2000 revs (check the torque curves in the manual).
Again, because the turbo 250 is a heavier car, has longer gear ratios and its throttle response is rubbish compared to the S2's, the S2 will feel faster off the line.
The turbo 250 is a supersport car while the S2 is a super sportscar.
A quick scan of the handbook gives roughly
2nd gear 6,500 rpm 110km/h in the turbo
2nd gear 6,500 rpm 95Km/h in the S2
and in
5th gear 6,500 rpm 170mph turbo
5th gear 6,500 rpm 155mph S2
Tony
ORIGINAL: Big Dave UK
Regards to the gear ratios...
The only difference is in 5th gear ... All the other gear ratios are the same....as an S2....
Ive just been checking it out as im looking at putting a 250T box with lsd, into my S2....
See above.......
Just be careful you are not over gearing. I had a motor bike as a teenager that was one tooth over on the front sproket and on paper it should have been faster but it was unable to pull its max speed at the red line( or even close to the red line), and actually had a max speed higher in fourth gear than in fifth. Changed it the next time time I got pocket money.
Saying that tho I might be a bit biased because the 944S is gutless in town (under 3800 rpm)and I only ever see fourth or fifth on the motor way, which is world apart from my previous 535i which would happily idle along in fifth all round town all day. (huge torque and far more relaxed, put the 944S foibles aside is far more focused).
