Whats best valance or splitter?
- Thread starter cococola
Kevin Welch
Peter Empson
But saying that I may remove it soon []. I'm struggling with the idea of keeping a non functioning part on a car that's going on another fairly strict diet. Plus I can't help feeling it must add drag, the airflow under the car getting caught up in its scoop shape, and it does look a lit dumpy from the side []
I'm not sure what, if anything will replace it just yet, but the supposed cooling/aerodynamic benefits of the turbo valance means its in the running...
sawood12
I have seen photo's somewhere for a proper rear diffuser but it was so low (as it would have to be to make it effective) that it wouldn't be suitable for the road.
pauljmcnulty
ORIGINAL: cococola
I have a 944 1986 model and I want to improve my rear end.I have located a slotted lower rear valance and the Turbo style rear splitter. My question is which one do you think looks best for my car??
Many thanks for any reply in advance.[]
See profile picture left.
I quite like it, and if John says it makes me look butch then that's cool with me....[]
ORIGINAL: cococola
.....Looks straight forward to fit[]
I've heard it described in many ways, none of which would get past the forum word sensor. Strangely enough none said it was straight forward.
I think the main problem comes when needing to drill into double skin sections that you can't get to the back of....But then it is a Porsche; so spending four hours taking off bits to get access to a job that only takes ten minutes is quite normal.
Peter Empson
ORIGINAL: cococola
Well I settled for the splitter and bought one off a rgular supplier on ebay for 85.00 inc postage.
Can you let us know how the install goes?
Also, what do you think of the quality of the splitter? If I go down this route I will certainly be considering getting one from him too.
Best regards,
Peter.
cococola
The quality of the splitter is good,it comes in primer ready for painting and the only thing I had to do before it was painted was to drill 2 holes that hadnt been predrilled.I will let you know how I get on with the fitting once done.
These are readily available still on ebay from the same supplier still.
Alan
