Monkeythree
Eight and a half.
Hi Edh, yes it is an S2, not checked inside of sills ,car has not been used during winter months .ORIGINAL: edh 944S2? ~£6-7k I'd say, if it's a nice one. Have you checked inside the sills?
Hi Paul, all servicing has been done by the same Porsche specialist, half engine was fitted by Porsche main dealer at 50,000 miles.ORIGINAL: pauljmcnulty Anything from £5K to perhaps £12K? As often discussed, there are so many potential bills.... Rust on sills and wings starts from the inside, so outside is no guide. Clutch, head gasket, brake and fuel lines, caliper refresh, suspension overhaul, I could go on! With rising values restoration is more viable, but it also means that some ropey cars are being listed as classics when they are really breakers. More details would help. I'd always want to see phone shots inside the sills, and copies of the last 5 years or so history. Belt change for example: could be a diy job that you wouldn't trust, or a full belt/seals/water pump/timing chain and tensioner service from a recognised specialist with the follow-up tension check.
I do my own belts-what's wrong with that?It's not hi-tech just a toothed belt for goodness sake-never used a gauge either. I also cut my own lawn-don't use an independant-am I not to trust that either? As it happens ,I also service all my lawnmowers of which I have 2 Atco's,3 Allen/Flymo's hovers & 2 petrol strimmers-looks like I'm heading for trouble. Even do my own gardening--now it's getting really serious-funny thing is -my plants grow very well-must be doing something wrong.[&o]ORIGINAL: pauljmcnulty . Belt change for example: could be a diy job that you wouldn't trust, or a full belt/seals/water pump/timing chain and tensioner service from a recognised specialist with the follow-up tension check.
As values rise, buyers will expect to see stamps from recognised specialists. No matter how good you maybe, a buyer will not know this. As an example the previous owner of mine was an engineer with a mechanic daughter, they did not look after it well. Didn't bother me at £1900 but would do at £15k and up.ORIGINAL: VITESSEI do my own belts-what's wrong with that?It's not hi-tech just a toothed belt for goodness sake-never used a gauge either. I also cut my own lawn-don't use an independant-am I not to trust that either? As it happens ,I also service all my lawnmowers of which I have 2 Atco's,3 Allen/Flymo's hovers & 2 petrol strimmers-looks like I'm heading for trouble. Even do my own gardening--now it's getting really serious-funny thing is -my plants grow very well-must be doing something wrong.[&o]ORIGINAL: pauljmcnulty . Belt change for example: could be a diy job that you wouldn't trust, or a full belt/seals/water pump/timing chain and tensioner service from a recognised specialist with the follow-up tension check.
Me too [ORIGINAL: VITESSEI do my own belts-what's wrong with that?It's not hi-tech just a toothed belt for goodness sake-never used a gauge either. I also cut my own lawn-don't use an independant-am I not to trust that either? As it happens ,I also service all my lawnmowers of which I have 2 Atco's,3 Allen/Flymo's hovers & 2 petrol strimmers-looks like I'm heading for trouble. Even do my own gardening--now it's getting really serious-funny thing is -my plants grow very well-must be doing something wrong.[&o]ORIGINAL: pauljmcnulty . Belt change for example: could be a diy job that you wouldn't trust, or a full belt/seals/water pump/timing chain and tensioner service from a recognised specialist with the follow-up tension check.
