Can someone please inform what the difference is between the naturally aspirated and turbo 944 2500cc models are please.
generally, manufacturers build the turbo model with forged internals such as crank rod piston setup but there are a surprisingly amount of engines with virtually identical internals on the basis the boost levels are quite low.
I'm curious to know the difference as I begin looking at the possibility of fitting a blower to to a nat aspirated engine running 5lbs of boost. I still consider I would be safe but it doesn't hurt to ask the question about how porsche did build them. It's probably irrelevant as the turbo models will run a higher boost than I will anyway.
cheers
Paul
cheers
Paul
