Whats your opinions?
- Thread starter Guest
Mystic Fen
Could this be related somehow to your AFR 'blip'?
I have the contact address for the UK distributor of Cometic gaskets.
ORIGINAL: Fen
Without wishing to sound like a doom-monger that's a lot of mayonnaise for it to be condensation, and I suspect you have used the car enough over the last few days that it's been warmed through...?
This is not related to the A/F blip.... But will definatly take that address and put it to one side as/when its required..
Diver944
944's do have a tendancy for the mayonnaise on the filler spout because it is so long , and in this cold weather there is a lot of moisture about, so it's rarely a head gasket. My S2 did this for 40,000 miles before I changed the stat last year. It improved a great deal by backing off the oil cap a little to let the moisture evaporate.
ORIGINAL: slim_boy_fat
They got a web site?
Yes - and a poorly laid out business card.
www.cometiceurope.com
NorthernBloke
One of the lads has a trade deal with Cometic. What sort of prices are you looking at and I'll see what he can do them for - just in case
Andy
I just want an MLS head gasket for my turbo - unless they do fancy studs as well? There aren't any in the catalogue I picked up so I guess not.
They're about $100 in the States so I'm expecting retail to be around £100, which is enough that I'd import. Something more around the £60 mark and I'd order it.
ORIGINAL: Diver944
Don't worry Slim. Mine looked exactly like that and worse before I had the thermostat changed (on both cars but the Turbo was always worse)
You know just he right things to say []
Kevin Welch
I had a Montego ( sad person ) that did exactly the same. It had a long filler tube right in the front of the engine and in the cold air flow. Cure was simple, I fitted some neoprene pipe lagging obtainable from a builders merchant, no more custard!!! I later found out that main dealers sold a specially shaped piece of neoprene lagging to cure the problem.
ORIGINAL: Kevin Welch
Hi Slim
I'm on the case []
How about a bulk purchase on gaskets just in case if we can get a good price?
Whats special about an MLS gasket? (that website is a bit tedious without broadband)
Tony
MLS - Multi Layer Steel. Basically it is two thin steel gaskets that are attached round the edge with flat rings trapped between them. These rings have to be lined up on fitting but server to ensure the area around the top of the combustion chamber is especially compressed.
I attached a pic, but it didn't show up. Here is the address: http://forums.rennlist.com/rennforums/attachment.php?s=&postid=983837
Anyway gasket looks good, might be a usefull 'insurance' spare at the right price,
Tony
