This query follows a combination of a). front suspension play flagged on the mot b). vibration during recent track day (this was probably just bits of rubber stuck to the tyres but ...). As a result I've been checking the front suspension and also front wheel bearings.
Q1: How does one disambiguate (properly) front suspension play and wheel bearing slack? The car is on stands, and I wobble the wheel vertically (hands top and bottom). I jack the wishbone up a little to presumably support the suspension and I wobble again. Not much difference. Is that suspension play? I don't think so (see below). Is there a better test?
Q2: How tight do people adjust the front wheel bearings? The workshop manual says you should be able to shift the pressure plate with a screw driver by hand. Does this mean 'easily by hand' or 'it is a bit tight but it can be moved without applying leverage etc.'. After adjusting the wheel bearing, interpretting the workshop manual as the latter, much of the 'suspension play' mentioned above has disappeared. Since I can still rotate the wheel, and the pressure plate, so this seems overall like a good thing right? There is less play in the wheel bearing.
Presmably the consequence of either too slack or tight wheel bearings is to shorten the life through increased friction. I'm probably worrying over nothing, but this post track day check over seemed prudent (and wheel bearings were suggested after my last post - which was a while ago but I just had a baby!). Lacking mechanical aptitute, I always find these 'matters of judgement' tricky.
cheers,
Chris
87 220T
cheers,
Chris
87 220T
