Wheel bearings
- Thread starter Guest
JCB..
Non-member
Wonder if my local garage can do it, don't know if I can be bothered to drive to nearest specialist for a run of the mill job like this.
They should be OK if you know them - I'd be inclined to hang around.
JCB..
vitesse
Telephone: 0208 959 1604
Fax: 0208 959 4697
Portiacraft
555/561 Watford Way, Mill Hill,
London NW7 4RT
marlin
ThanksORIGINAL: danofesher
They're definitely not listed as being covered.
Mine was doing this and i would have sworn it was a wheel bearing (rear N/S).
It turned out to be the Yokohama tyres that it came with had worn (stepped) on the inside edge and it was making the noise.
It made the noise when they were down to around 3mm and right up until i had new rear rubber fitted!
Noise was gone immediately!
Cheers!....Mark H.
