Clewsey
Hi all,
Couple of questions if I may:
I'm in the process of replacing the non-tasteful 19" fitted wheels with a recently purchased set of 18" Carrera classics front 8J x 18 H2 (Offset 50mm) rears 10J x 18 H2 (offset 47mm) to the 986 S. I understand that these won't require spacers. The question is will I be ok with standard wheel bolts? I'm assuming so?
Secondly, I want to do an engine oil change. As my engine is higher mileage (112k) I'm thinking of getting something that may be more appropriate for the engine protection. Would people advise 5W40 or 10W40? I think 0w40 will be too thin. What do folk recommend? I am intending on continuing to use Mobil 1 for it though.
Cheers,
Simon
Cheers,
Simon
