Jonathan G
Hi, while investigating some of the other issues I have submitted posts about in the last day or so I had something of a drama. When I was putting the front wheel back on(having checked rear side of brake disk, not as smooth or rust free as outward side) I used the Alloy locating pin that is part of the Porsche tool kit. Big mistake! When I screwed it in it appeared a little tight(sure I did not cross thread it). Put the wheel on and screwed in other wheel bolts but could not get the Alloy Pin out, stuck! Took all wheel bolts out and wheel off again and after 30 mins or so of carefully trying to undo it without snapping it off, WD40, etc it eventually worked it's way out. Really felt like the thread was not quite the correct match for the wheel bolt hole. All back together now but the wheel bolt for that hole was a little stiff also, I suspect because of residual aluminium on the thread.
Anyone any experience of this? I will not be using it again, I will just struggle on to locate the wheel without it!
